Sys-whonix high cpu usage
The sys-whonix (template=whonix-gateway-18) in Qubes 4.3 is consuming close to 100% of CPU. I ran top command and sorted by CPU and did not see any process consuming lot of CPU. In the attached image, the CPU usage is 92% but there are no process with high CPU usage. Any inputs on what could be the issue is appreciated.
