Hi there,
I am facing an issue with the sys-usb on my Dell Precision 7560.
I have a pop up “Device available”, “Device removed” that keeps being there on the top right of my screen.
When I do qvm-usb I received the following information :
"sys-usb:2-14 : " (it has no name).
When I try to attach it to a VM, i get the following error :
“Device attached failed: No device info received, connection failed, check backend side for details”
From the documentation it seems like it is the incompatibility problem.
Can I do anything to stop that pop up, or to try to identify which device is causing problem with my computer ?
Thank you in advance
