but an error message is returned in response to the command:
sudo qubes-dom0-update --action=reinstall sys-usb
Errors during downloading metadata for repository ‘qubes-dom0-cached’:
Curl error (37): Couldn’t read a file:// for file:///var/lib/qubes/updates/repodata/repomd.xml [Couldn’t open file /var/lib/qubes/updates/repodata/repomd.xml]
Error: Failed to download metadata for repo ‘qubes-dom0-cached’: Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried
I already have a sys-usb VM but there is a package in there which is taking up way too much disk space and i can’t get the termianl to open. So the next step is to re-install.
