I have changed my AppVMs to the Fedora-38 template.
Now only in sys-usb I can’t use the system tray icon, the terminal(run-terminal) and Open File Manager.
If I use the Debian-11 template for sys-usb then it works.
How is the icon called via the system tray icon for the two apps(terminal, files)?
