This is minor but annoying and I’d like to understand why it’s happening. In the last few days when I boot the sys-net icon is not in the tray. It reappears with a restart of sys-net.
Does anyone have any ideas why it might be happening? How do I access the list of available networks without the tray icon?
Hmm, I had a similar issue in the past and found out, that it appears because I changed to a dark theme. Can you switch back to the original white theme and test, if sys-net is working fine then…
I’m really sure, that this will be the problem. You unfortunately have to live with it for the time being, but -for me- it finally was solved one day, during the weekly OS updates. You probably just have to wait for that too.
