in my global config in usb devices tab I have usb qube shows as sys-usb AND sys-net
is this ok or did I do something
Hi @bobzenub, Welcome to the forum
It seems you selected (Use sys-net qube for both networking and USB devices) during the installation.
This might also be useful to you:
no I didnt select that
so are you telling me this is not the way it should be?
how can I make this right
Sorry for my incorrect assumption.
Not exactly
it doesnât appear that way for me. However, if the network or Ethernet adapter is being detected as a USB device, that would explain why it shows up the way it does. (Could you check exactly what is connected?)
Someone more experienced than me might be able to help you (this seems like a problem Iâm not familiar with).
