PLEASE HELP!
hvm please
ADVANCED tab → Virtualization: HVM & Kernel: default or none
do I get to the advanced tab through the qube manager?
yes, Qubes Setting of that sys-net qubes
should I change kernel to none?
Nah you don’t need to cahnge it to none, but in the DEVICE tab select both ethernet and Network controllers to the selected area one at a time if you don’t careful enough. Then hit OK and restart the qube.
okay, I will try that again I tried it recently and it didnt work
In the ADVANCED tab, Memory/CPU must have no memory balancing and the initial memory shall be at 400MB and in the OTHER: Provide network with a check in the box. In the BASIC tab, Settings: start qube automatically on boot check in the box also.
After that, restart the whole entire OS to see any workages for the qubes.
In the BASIC tab, Setting: Net qubes shall be none also.
okay thankyou I will do everything you told me and come back to update you
I havent restarted yet but I checked everything you said and everything looks right. my template is set at fedora-34 and my net qube is none eith both having caution symbols next to them. in my devices I have both my network and ethernet in there. anything else you could recommend to fixing the problem before I restart? as the restart process takes a little time
in basic tab it also says, private max storage size 2.0 gb
Does it still works?
Don’t be concern about the applications. Also, are you using BSD?
Admins, false alarm for the report. I may have a solution.
