I reinstalled qubes os on the latest version.
sys-net dont start automatically. If i try to start i got the error “Got empty response from qubesd. See journalctl in dom0 for details”
Wen i try to shut it off i got “Error: Domain is powered off: sys-net”
State is Transient
I cant restart it.
I tried to reinstalled it but the problem is still the same. I also tried (non)disposable in the first settings.
I hope someone can help
Do you have sys-usb qube? Is it starting successfully?
Can you start any qube with net qube set to none, e.g. vault?
Do you have these options enabled in BIOS?
- Intel VT-x with EPT or AMD-V with RVI
- Intel VT-d or AMD-Vi (also known as AMD IOMMU)
You can try to remove PCI devices from sys-net and start it. Maybe one of the PCI devices attached to sys-net is causing it.
You can also check the log in dom0 terminal using journalctl command to see the exact error when sys-net is trying to start:
journalctl -b
yes, i have a usb cube that starts. Everything else starts successfully if i set net qube to none.
I dont no what options in BIOS that are, but in earlyer instalations that problem doesnt exist so i dont think that bios is the problem.
journalctl -b gave me this output (sorry for the quality)
You need to scroll the log using PgUp/PgDown to search for the related errors.
Or you can run this command:
journalctl -f -n0
And start sys-net, then check the command output to see the errors.
Also try to remove remove PCI devices from sys-net Settings-> Devices tab one by one to see which device is causing this issue.
