I have installed sys-gui (non-gpu, non-vnc) using the official documentation:
I have an issue where on a fresh boot, if I first log into dom0, then log out, xfce4 will not successfully bootstrap when I then log into sys-gui.
Here are some timestamps which may help with the logs I will post.
- 16:12PM powered on laptop, went through LUKS decryption
- 16:13PM logged in as
adminto dom0, then signed out (session saved) - 16:14PM paused to give space in the logs
- 16:15PM logged into
engineer(sys-gui), mouse cursor works, but xfce does not fully start - 16:16PM
ctrl+alt+f2, log in asadminin dom0 - 16:17PM
sudo journalctl --since=today | grep -G 16:1. > greplogs.txt, thenqvm-shutdown --force sys-gui
Here are the contents of greplogs.txt:
I am, however, able to get into sys-gui, if I log into it first, or if I shutdown my locked up sys-gui, and then sign back into it afterwards:
- 16:18PM Mistyped
engineerpassword, then tried again and signed in, xfce starts - 16:19PM Switched back to dom0 tty, logged to greplogs2.txt, and then
qvm-shutdown --force sys-guiand shut down the laptop after
Here’s the slightly longer greplogs2.txt (a superset of the first log file)
