I am willing to give GUI domain a try. I have followed the documentation for the hybrid version. As a final step it instructs:
“At this point, you need to shutdown all your running qubes as the default_guivm qubes global property has been set to sys-gui.”
So, I have rebooted the computer.
“In order to use sys-gui as GUI domain, you need to logout and, in the top right corner, select lightdm session type to GUI domain (sys-gui).”
OK but there is no such option on top right. There I have only one choice - XFCE Session. I can simply login as usual and I don’t see any changes, apart from a running VM named sys-gui. Executing systemctl status lightdm shows that this service is running but I don’t notice any speed up of visual UI. For example, the scrolling in the text editor of the default “untrusted” VM is still choppy.
I didn’t try sys-gui myself so I can’t help you out here. I can just guess that you missed something during sys-gui setup and it didn’t install properly. I can just suggest you to look through these threads and try to figure out what’s missing:
I have gone through all the threads you linked but there is no answer to my question there.
Something more: I tested what one of the threads suggests and created a test-vm, then I set its guivm to sys-gui through qvm-prefs. Then I tried to run apps in test-vm (XTerm, Firefox). Result: nothing shows. I also notice that I can’t even open a terminal in sys-gui itself. OTOH, I notice some CPU load (~14%) on sys-gui when looking at the running Qubes in tray menu, even with test-vm not running at all.
I really hope someone can shed some light on this.
The section in documentation called “Delete GUI domain” explains how to set default_guivm as dom0. However, this seems unnecessary in my case as it already isdom0. Right?
Also, when I installed the sys-gui there were no error messages when running the qubesctl commands, only success was reported, so there is nothing to post.
After giving up on sys-gui and removing it from the system, today I decided to try sys-gui-gpu, as I do have an Intel VGA (integrated in the CPU).
Following strictly the instructions in the docs, after rebooting, I was unable to use sys-gui-gpu too - after login, it is not running. The moment I attempt to start it manually, the whole computer experiences a hard reset. I retried the whole procedure but that didn’t change anything, except that the second time the system reset happened instantly at the last step:
After booting, next attempts to start sys-gui-gpu resulted in the same - hard system reset. I looked at /var/log/qubes/*sys-gui-gpu.log files but saw nothing informative:
/var/log/qubes/qubesdb.disp-mgmt-sys-gui-gpu.log
vchan closed
reconnecting
vchan closed
/var/log/qubes/qrexec.disp-mgmt-sys-gui-gpu.log
/var/log/qubes/qubesdb.sys-gui-gpu.log
vchan closed
reconnecting
vchan closed
/var/log/qubes/mgmt-sys-gui-gpu.log
2023-09-18 14:11:58,819 calling 'state.highstate'...
2023-09-18 14:12:47,405 output: sys-gui-gpu:
2023-09-18 14:12:47,406 output: ----------
2023-09-18 14:12:47,408 output: Summary for sys-gui-gpu
2023-09-18 14:12:47,408 output: ------------
2023-09-18 14:12:47,409 output: Succeeded: 4 (changed=4)
2023-09-18 14:12:47,409 output: Failed: 0
2023-09-18 14:12:47,409 output: ------------
2023-09-18 14:12:47,409 output: Total states run: 4
2023-09-18 14:12:47,409 output: Total run time: 66.089 ms
2023-09-18 14:12:47,409 exit code: 0
2023-09-18 15:10:16,171 calling 'state.highstate'...
/var/log/qubes/qrexec.sys-gui-gpu.log
2023-09-18 14:12:47.509 qrexec-daemon[46478]: qrexec-daemon.c:1264:main: qrexec-agent has disconnected
domain dead
2023-09-18 14:12:48.469 qrexec-daemon[46478]: qrexec-daemon.c:1149:handle_agent_restart: cannot connect to qrexec agent: No such process
2023-09-18 14:12:48.469 qrexec-daemon[46478]: qrexec-daemon.c:1266:main: Failed to reconnect to qrexec-agent, terminating
I thought it might be a good idea to share this here before submitting any bug reports. Hopefully, someone may provide some feedback if there is anything that can be done to make this work.
