Sys-firewall restarting issue when 2 different qubes running
See post 3
Just in case anybody is interested
debian-13-min does not work as good as its fedora counterpart as a minimum template for sys-firewall. I receive quite a few error messages when starting and restarting qubes but those messages do not happen if i use the fedora-minimal template.
I will try and post some examples if I have some time.
4.3rc3
Examples would be helpful, as would a list of additional packages you have installed. I’m on r4.2.4 and haven’t noticed any errors due to my debian-13-minimal based sys-firewall. I’ve allocated 250MiB initial and 400MiB max memory, with memory balancing, and only one VCPU.
Actually its not even minimum template related, it even happens with default-dvm which in my case is debian-13-xfce.
So this was just a heads up because it was 4.3rc3 and I was not sure what caused the error and I thought it just happened on deb-min but I can now reproduce it in fed-min and deb-min. I also think this might be related to the preloaded issue I have already reported.
Start 2 different qubes (say default-dvm and firefox-only-dvm) (mine both happen to be preloaded qubes) then restart sys-net and sys-firewall, firewall will not restart and Qubes Manager will crash (And a few other error messages will appear). It could be a config issue because I have just used the 4.2.4 docs on sys-* minimum template.
HTH
