Sys-audio is starting before sys-usb despite device assignment config
hello, I have both sys-usb and sys-audio configure to automatically start on boot.
my issue is that sys-audio will sometimes start before sys-usb (crucially before my usb bluetooth adapter(s)) which breaks the blueman panel icon.
I am unable to set the adapter(s) as required devices as they use USB technology, and are not always in the same port (which I crudely solved by assigning an instance of the adapter in each USB port to sys-audio so that at least one will be assigned at any given time)
this is not a big issue, as I can enter the blueman-manager manually, but the missing panel icon is an annoyance.
my theorized solutions: force sys-audio to wait for sys-usb to start before starting. force sys-audio to wait for at least 1 USB bluetooth adapter to exist before starting
I would greatly appreciate any help on this matter. thank you.
still facing this problem with the blueman panel icon.
I’ve made .desktop file for that in sys-audio
[Desktop Entry]
Name[pl]=Adaptery Bluetooth
Name=Bluetooth Adapters
Comment[pl]=Ustaw właściwości adaptera Bluetooth
Comment=Set Bluetooth Adapter Properties
Exec=sh -c "blueman-adapters & sleep 3 && xdotool search --name 'Bluetooth Adapters' windowclose"
Icon=blueman-device
Terminal=false
Type=Application
Categories=X-XFCE;Settings;HardwareSettings;X-XFCE-SettingsDialog;GTK;
StartupNotify=false
NoDisplay=false
X-XfceSettingsName=Bluetooth
X-XfcePluggable=true
Path=
