Switching to KDE in 4.3.0-rc4 does not work for me
I tried to switch my test installation (Lenovo ThinkPad E14) from XFCE to KDE Plasma.
I followed the steps as described in
and I was able to switch / log into KDE.
However when I followed the steps in the ‘Welcome Center’ concerning ‘Access the Internet’ I received the information that ‘plasma-nm’ needs to be installed - and - that I’m supposed to report this as a bug to the Qubes Team.
Do you need any other information for me ?
PS: Switching back to XFCE ( and accessing the Internet again :wink: worked w/o any issues !
Dont do this - just use sys-net as you do normally. If you have already
set up a network connection then it will Just Work™
BUT the network manager applet is in the status bar with a blank icon -
you can hover over it and control NM as usual.
@unman: Thanks a lot for your quick feedback !
I’ll retry my switch from XFCE to KDE later in the evening …
You are right, the network is working as is …
I’ll work a bit more with KDE as the DE for Qubes OS & provide an update in a couple of days …
Its confusing for two reasons:
  1. The KDE tools dont understand about the role that dom0/GuiVM has in
    Qubes, so the advice can be misleading. (Actually the same goes for most
    DE)
  2. The network manager applet isnt obvious on the task bar. Long running
    bug in KDE.
There’s a lengthy thread about KDE - I’d suggest taking it slow, but set
up a few Activities and allocate qubes to them; Add some shortcuts to
load windows and switch between activities; Customise the KDE menu.
I’m convinced that KDE is a fine match for Qubes and makes Qubes use
easier, simpler, and more productive.
