stuck at custom partitioning in installation target in qubes 4.1
can anyone in detail reply on disk use and partition type and disk allotment for qubes
check my featured post for clue about custom partitioning.
for uefi you need :
efi partition
boot partition
root partition with root-pool
data partition with vm-pool
thanks a lot
sir , why automatic partioning is not happening in qubes 4.1 at installation target
my spects
- i5 11 gen with 16 gb ram , 500 gb ssd, integrated intel xe graphics
error showing on clicking on automatic partition
→ resource to create this format lvmpv is unavailable
reboot first then do automatic partition don’t forget to select disk and reclaim space
yes sir, i have first seclected disk > selected encrypt my data > delete all > reclaim space
then this error pops up everytime whether the target installation is 500 ssd internal or 128gb pendrive
