Here is the complete, updated Stremio Native Qubes OS guide in clean, copy-pasteable text format, incorporating fedora-44-xfce and fedora-minimal templates, direct binary menu execution, and DisposableVM persistence.
Stremio Native on Qubes OS (Fedora 44 XFCE & Minimal Templates)
1. Configure Qubes VM Settings (Before Starting)
dev-vm(Temporary Build AppVM):- Private storage max size:
25600 MB(25 GB) - Initial / Max memory:
8192 MB(8 GB) — uncheck Include in memory balancing during the build - vCPUs:
4
media-vmordvm-template(Playback AppVM / Disposable Template):- Private storage max size:
10240 MB(10 GB) or higher - Initial / Max memory:
4096 MBto6144 MB - vCPUs:
4(recommended for smooth CPU video decoding in Qubes)
2. Build stremio-native Inside dev-vm
2A. Install Temporary Build Dependencies
Open a terminal in dev-vm and install RPM Fusion, C++/vcpkg build tools, lld, and development headers (these stay temporary in dev-vm and wipe on reboot):
bash
sudo dnf install -y \
https://rpmfusion.org(rpm -E %fedora).noarch.rpm \
git gcc gcc-c++ make cmake ninja-build pkgconf-pkg-config clang llvm-devel lld \
perl-core curl zip unzip tar \
mpv-devel gtk3-devel openssl-devel sqlite-devel dbus-devel libsecret-devel \
mesa-libGL-devel mesa-libEGL-devel fontconfig-devel freetype-devel expat-devel \
libxkbcommon-devel libxkbcommon-x11-devel wayland-devel \
libX11-devel libXcursor-devel libXi-devel libXrandr-devel
2B. Install Rust, Clone Repository & Bootstrap vcpkg
bash
curl --proto '=https' --tlsv1.2 -sSf https://sh.rustup.rs | sh -s -- -y
source "$HOME/.cargo/env"
cd ~
git clone --recurse-submodules https://github.com
cd ~/stremio-native
git clone https://github.com
./vcpkg/bootstrap-vcpkg.sh -disableMetrics
2C. Compile libtorrent 2.1.1 via vcpkg
bash
cd ~/stremio-native
./vcpkg/vcpkg install \
--x-manifest-root="$PWD" \
--x-install-root="$PWD/vcpkg_installed" \
--triplet=x64-linux-v3-static-release \
--overlay-triplets="$PWD/triplets" \
--overlay-ports="$PWD/vcpkg-overlays"
2D. Compile stremio-native
bash
cd ~/stremio-native
mkdir -p ~/tmp
unset PKG_CONFIG_ALL_STATIC
export TRIPLET="x64-linux-v3-static-release"
export PKG_CONFIG_PATH="$PWD/vcpkg_installed/$TRIPLET/lib/pkgconfig"
export VCPKG_ROOT="$PWD/vcpkg"
export VCPKG_DEFAULT_TRIPLET="$TRIPLET"
export RUSTFLAGS="--cfg rustix_use_libc -C link-arg=-fuse-ld=lld -C link-arg=-Wl,--strip-all"
export CARGO_PROFILE_RELEASE_LTO=false
export CARGO_PROFILE_RELEASE_CODEGEN_UNITS=16
export CARGO_PROFILE_RELEASE_DEBUG=0
export TMPDIR="$HOME/tmp"
cargo build -j 2 --release --package stremio-native
3. Transfer the Compiled Binary
In dev-vm, send the standalone binary to your playback AppVM or Disposable Template:
bash
qvm-copy ~/stremio-native/target/release/stremio-native
4. Install Runtime Libraries in Your Target TemplateVM
Open a terminal in the TemplateVM used by your playback qube (clone it first if you want to keep the base template unmodified).
Option A: Standard fedora-44-xfce Template
fedora-44-xfce already includes GTK3, Mesa OpenGL, X11/Wayland, and fonts. Install only RPM Fusion and mpv-libs:
bash
sudo dnf install -y mpv-libs libsecret
Option B: fedora-minimal Template (e.g., fedora-45-minimal)
Open a root shell from dom0 via qvm-run -u root <minimal-template> xterm and install Qubes agents, fonts, and runtime libraries:
bash
dnf install -y \
dnf install -y \
qubes-core-agent-networking pipewire-qubes \
mpv-libs gtk3 libsecret gnome-keyring dbus-daemon ca-certificates \
mesa-libGL mesa-libEGL mesa-dri-drivers \
libxkbcommon libxkbcommon-x11 libX11 libXcursor libXi libXrandr \
libwayland-client libwayland-cursor libwayland-egl \
fontconfig freetype dejavu-sans-fonts
Shut down the TemplateVM after installing so the changes persist.
5. Set Up Binary & Qubes Menu Entry (Direct Launch)
In your playback AppVM or Disposable Template (e.g., fedora-44-dvm), move the binary into place and create a .desktop launcher pointing directly to the ELF binary with Path locked to ~/stremio-app (replace <dev-vm-name> with your dev qube’s exact name):
bash
mkdir -p ~/stremio-app ~/.local/share/applications
mv ~/QubesIncoming/<dev-vm-name>/stremio-native ~/stremio-app/
chmod +x ~/stremio-app/stremio-native
cat << 'EOF' > ~/.local/share/applications/stremio-native.desktop
[Desktop Entry]
Name=Stremio Native
Comment=Native Rust & Slint client for Stremio
Path=/home/user/stremio-app
Exec=/home/user/stremio-app/stremio-native
Terminal=false
Type=Application
Categories=AudioVideo;Video;Player;
EOF
Then sync the Qubes application menu from dom0 (replace <target-vm-or-dvm-template> with your qube’s name):
bash
qvm-sync-appmenus <target-vm-or-dvm-template>
6. Configure Addons & HDR Persistence (For DisposableVMs)
- Start your Disposable Template (e.g.,
fedora-44-dvm) and launch Stremio Native from the Qubes menu (or runcd ~/stremio-app && ./stremio-native). - Use a local profile (not Guest Mode): Select or create a local profile (such as the default local Owner profile) so addons save permanently inside
~/stremio-app/storage/. - Set HDR Mode: Open Settings → Playback → HDR Mode and select Tone Map (or Disabled) so HDR videos render with accurate colors on Qubes’ SDR display.
- Close Stremio Native cleanly so SQLite flushes to disk, then shut down the Disposable Template completely before launching new DispVMs.
7. Clean Up dev-vm
Once you confirm Stremio Native launches and plays video properly in your playback qube, free up ~15 GB in dev-vm:
bash
rm -rf ~/tmp ~/stremio-native ~/.cargo ~/.rustup
Images edited to text with help of AI
Any Suggestions are more than welcome.
