Today, when I open Whonix Workstation terminal, I got dozens and dozens of notifications about error, saying “Denied: qubes.UpdatesProxy from whonix-workstation-17 to”… Can’t read further because can’t open in journal full message. It happens when I just open terminal. I do nothing in it.
I checked in dom0 terminal, using journalctl -f command and found many of such error messages: “dom0 qrexec-policy-daemon[3673]: qrexec: qubes.UpdatesProxy: whonix-workstation-17 -> : denied: denied by policy /etc/qubes/policy.d/50-config-updates.policy:1”
Also found there two strange red error messages, that I did not see before, saying on Russian: “dom0 pulseaudio[6746]: ALSA сообщила о возможности записи новых данных в устройство, но на самом деле писать было нечего.”
And:
“Скорее всего, это ошибка в драйвере ALSA «snd_hda_intel». Пожалуйста, сообщите об этой проблеме разработчикам ALSA.”
It can be translated as: “dom0 pulseaudio[6746]: ALSA reported the possibility of writing new data into the device, but in fact there was nothing to write”
And:
“This is likely a bug in the ALSA «snd_hda_intel» driver. Please report this problem to ALSA developers.”
I don’t know why these errors appear. I did nothing special in Qubes. All I can assume is that maybe it can be somehow related to not updated Whonix Workstation. I missed last update and was going to update it today when will have a time. ![]()
UPDATE: Also while was writting all of this, found another three big red error messages in dom0 terminal that never seen before:
Xen free = 193251410 too small for satisfy assignments! assigned_but_unused=204798857, domdict={'0': {'memory_current': 3930230784, 'memory_actual': 3947009939, 'memory_maximum': 4294967296, 'mem_used': 1146249216, 'id': '0', 'last_target': 3947009939, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': False}, '1': {'memory_current': 402698240, 'memory_actual': 402698240, 'memory_maximum': 419430400, 'mem_used': None, 'id': '1', 'last_target': 402653184, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': False}, '2': {'memory_current': 150994944, 'memory_actual': 150994944, 'memory_maximum': 150994944, 'mem_used': None, 'id': '2', 'last_target': 150994944, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': False}, '3': {'memory_current': 402698240, 'memory_actual': 402698240, 'memory_maximum': 419430400, 'mem_used': None, 'id': '3', 'last_target': 402653184, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': False}, '4': {'memory_current': 150994944, 'memory_actual': 150994944, 'memory_maximum': 150994944, 'mem_used': None, 'id': '4', 'last_target': 150994944, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': False}, '5': {'memory_current': 1119260672, 'memory_actual': 1135974345, 'memory_maximum': 4194304000, 'mem_used': 407384064, 'id': '5', 'last_target': 1135974345, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': True}, '6': {'memory_current': 1775083520, 'memory_actual': 1791798825, 'memory_maximum': 4194304000, 'mem_used': 642576384, 'id': '6', 'last_target': 1791798825, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': True}, '10': {'memory_current': 3028353024, 'memory_actual': 3166231956, 'memory_maximum': 4194304000, 'mem_used': 1175814144, 'id': '10', 'last_target': 3166231956, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': True}, '12': {'memory_current': 1093586944, 'memory_actual': 1110298736, 'memory_maximum': 4194304000, 'mem_used': 398176256, 'id': '12', 'last_target': 1110298736, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': True}}
dom0 qmemman.systemstate[3065]: Xen free = 193251410 too small for satisfy assignments! assigned_but_unused=204798857, domdict={'0': {'memory_current': 3930230784, 'memory_actual': 3947009939, 'memory_maximum': 4294967296, 'mem_used': 1146249216, 'id': '0', 'last_target': 3947009939, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': False}, '1': {'memory_current': 402698240, 'memory_actual': 402698240, 'memory_maximum': 419430400, 'mem_used': None, 'id': '1', 'last_target': 402653184, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': False}, '2': {'memory_current': 150994944, 'memory_actual': 150994944, 'memory_maximum': 150994944, 'mem_used': None, 'id': '2', 'last_target': 150994944, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': False}, '3': {'memory_current': 402698240, 'memory_actual': 402698240, 'memory_maximum': 419430400, 'mem_used': None, 'id': '3', 'last_target': 402653184, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': False}, '4': {'memory_current': 150994944, 'memory_actual': 150994944, 'memory_maximum': 150994944, 'mem_used': None, 'id': '4', 'last_target': 150994944, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': False}, '5': {'memory_current': 1119260672, 'memory_actual': 1135974345, 'memory_maximum': 4194304000, 'mem_used': 407384064, 'id': '5', 'last_target': 1135974345, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': True}, '6': {'memory_current': 1775083520, 'memory_actual': 1791798825, 'memory_maximum': 4194304000, 'mem_used': 642576384, 'id': '6', 'last_target': 1791798825, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': True}, '10': {'memory_current': 3028353024, 'memory_actual': 3166231956, 'memory_maximum': 4194304000, 'mem_used': 1175814144, 'id': '10', 'last_target': 3166231956, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': True}, '12': {'memory_current': 1093586944, 'memory_actual': 1110298736, 'memory_maximum': 4194304000, 'mem_used': 398176256, 'id': '12', 'last_target': 1110298736, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': True}}
dom0 qmemman.systemstate[3065]: Xen free = 193251410 too small for satisfy assignments! assigned_but_unused=188019702, domdict={'0': {'memory_current': 3930230784, 'memory_actual': 3947009939, 'memory_maximum': 4294967296, 'mem_used': 1146249216, 'id': '0', 'last_target': 3881291978, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': False}, '1': {'memory_current': 402698240, 'memory_actual': 402698240, 'memory_maximum': 419430400, 'mem_used': None, 'id': '1', 'last_target': 402653184, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': False}, '2': {'memory_current': 150994944, 'memory_actual': 150994944, 'memory_maximum': 150994944, 'mem_used': None, 'id': '2', 'last_target': 150994944, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': False}, '3': {'memory_current': 402698240, 'memory_actual': 402698240, 'memory_maximum': 419430400, 'mem_used': None, 'id': '3', 'last_target': 402653184, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': False}, '4': {'memory_current': 150994944, 'memory_actual': 150994944, 'memory_maximum': 150994944, 'mem_used': None, 'id': '4', 'last_target': 150994944, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': False}, '5': {'memory_current': 1119260672, 'memory_actual': 1135974345, 'memory_maximum': 4194304000, 'mem_used': 407384064, 'id': '5', 'last_target': 1135974345, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': True}, '6': {'memory_current': 1775083520, 'memory_actual': 1791798825, 'memory_maximum': 4194304000, 'mem_used': 642576384, 'id': '6', 'last_target': 1791798825, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': True}, '10': {'memory_current': 3028353024, 'memory_actual': 3166231956, 'memory_maximum': 4194304000, 'mem_used': 1175814144, 'id': '10', 'last_target': 3166231956, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': True}, '12': {'memory_current': 1093586944, 'memory_actual': 1110298736, 'memory_maximum': 4194304000, 'mem_used': 398176256, 'id': '12', 'last_target': 1110298736, 'use_hoplug': False, 'no_progress': False, 'slow_memset_react': False, 'use_hotplug': True}}
Don’t know if it is somehow related to errors described above or not. Wrote for any case. I would use spoilers for such big messages but seems this site doesn’t have that function.
