Strange dom0 update output
so is this normal? is there something I’m supposed to fix ? if so how please
sudo qubes-dom0-update --clean
Using sys-firewall as UpdateVM to download updates for Dom0; this may take some time...
warning: Converting database from bdb to sqlite backend
Invalid configuration value: failovermethod=priority in /var/lib/qubes/dom0-updates/etc/yum.repos.d/fedora.repo; Configuration: OptionBinding with id "failovermethod" does not exist
Invalid configuration value: failovermethod=priority in /var/lib/qubes/dom0-updates/etc/yum.repos.d/fedora-updates.repo; Configuration: OptionBinding with id "failovermethod" does not exist
Warning: Enforcing GPG signature check globally as per active RPM security policy (see 'gpgcheck' in dnf.conf(5) for how to squelch this message)
0 files removed
See: https://forum.qubes-os.org/t/qubes-dom0-update-strange-message-invalid-configuration-value-failovermethod-priority/
