Stop leaking template name in appvm!
Im honestly kinda shocked… why the heck are you allowing any app to sniff template name in a regular appvm??? It’s really pissing me off because this kinda data is critical… and it’s by design??? wtf…
so… if you go into any appvm and AS REGULAR USER try to qubesdb-read /qubes-base-template it will show you the template of the appvm!!!..
  1. WHY is this like that???
  2. HOW do I stop appvm to leak my template names???
It was added as part of #1101, which states “VM already has ability to get the template name (for example from logs), so this will not pose additional data leak.”
I’d suggest giving your templates boring enough names instead.
Why do you care? What’s your threat model if it includes things like this?
so instead of fixing logs etc… they decided to just give up??? what kinda logic is that…
and this was over a decade ago… didnt they know what fingerprinting is back then? highly doubt it… so why… WHY… I cant access that google thing from TOR…
because this is CRITICAL identification data… and if for whonix its working because the template name is the same among everyone… regular template names ARE NOT!!! so you may do WHATEVER you like but you will NOT gain any privacy…
If your concern is software running in two different qubes finding out that they are based on the same template: The software doesn’t even need the template name for that at all. Taking inventory of installed packages, file timestamps on the root volume, etc. should do the trick. (But a website running in an unexploited browser can’t do this, nor query qubesdb for the template name.)
Im not talking about website… obviously it’s about a potentially malicious app running on whatever template…
so say I have gazillion of templates… each for one app or whatever… APPS should NOT have access to this kinda data… wtf?!
are you really all ok with that???
The app qube would only see the name of its 1 template though. Not the gazillion minus 1 names of the other templates that may exist on the system.
Breathe.
The question then is: why are you putting “CRITICAL identification data” into your template names? Also, what would an adversary gain if they were to gain access to that CRITICAL data?
it’s like saying why you care about privacy if you dont have anything to hide… dude… come on…
template names are my INTERNAL way of ORGANIZING things…
good… now… THINK…
I think it would be helpful if you were to set out what threat model you
are concerned about, what is the specific issue you see here, and why
it matters.
Is it that a malicious actor could identify the name of the template
used by this qube? Could that be used to fingerprint you and in what
circumstances?
Is it because it might be possible to correlate use of templates between
different qubes?
In the naming scheme you have adopted are you really using “CRITICAL
identification data”? Why? It might be better not to use “CRITICAL
identification data”,(whatever that might be), anywhere on the system.
A weak way I can think of is simply not having qubesdb package in your vm, but it shoud break things. Also malicious program might bring its own qubesdb client
@rustybird I know you know it better than I do, perhaps there is a policy one could set to deny reading certain keys, or obfuscate them?
I think there is not any such policy in place at the moment, (or
framework to support it.)
I have filed an issue and invite readers to participate:
It is a little unintuitive to me that the name of a template would be accessible to an app qube. Or for that matter, even that the name of the app qube would be accessible to that same qube. For example, if I trap someone inside of a box, I’d assume that they wouldn’t be able to find out what color I painted the outside of that box, or the existence of or the details of a label I stuck to the outside of it.
A more practical example, I’ll stop this now that I’m aware of this thread, but I’ve had a habit of naming my qubes with references to different books/films I like, which apparently could give an attacker personal information about my tastes, separately from the fingerprint (packages, logs, etc.) that could obviously be taken from the inside of the qube.
I guess I assumed that packages, logs, files, etc. are ‘inside’ a qube, while the name, color, etc. are ‘outside’ the qube.
I’m also a bit confused - it’s written clearly in the linked issues above that the template name is available in the VM logs, but I haven’t seen any clear reason why this is the case / the desired outcome ?
It is the case, (as with other references) because the qube inherits
most of the filesystem from the template, as is clearly documented.
So eg logs from the template appear in the qube: it’s a consequence of the
template/qube design.
I understand that the VM inherits from the template’s FS, and that some of the template’s logs will appear in the VM - but it’s not clear why the template’s name, which to me seems like a cosmetic, “outside” property, appears inside the template’s inner logs
VMs (including TemplateVMs) set their hostname from the VM name during startup:
That’s also why the VM name appears in the shell prompt by default.
This is why i started this project https://codeberg.org/dkzkz/apparmor-qubes by using apparmor to deny access to critical information for app like the machine-id of the users , the version of debian etc… i also asked @unman if in the future every debian template could ship with those apprmor profile for browsers and some apps.
You can also mix kicksecure and my apparmor profile but even with that a app will still be able to see if you’re using qubes or not
But i’m agree on this point by default apps should not see you’re using Qubes and they must not see your appvm name. Privacy and anonymity value is growing in the society. We never saw in the history so many apps and OS about privacy and anonymity i really think Qubes dev should make effort for this issue. By doing that Qubes will attract many other users and they will get more donation.
My response was that it would require much testing before this could be
applied. dkzkz posted looking for volunteer testers, but little apparent
response. If you want this sort of thing implemented, then get on board
with that testing.
It’'s not impossible to hide the qube name from the qube, although I am
yet to be convinced of the need for this. As to “not seeing you’re using
Qubes” that is very difficult, and most approaches are just theatre.
