Star Labs StarBook Mk V
layout:
  'hcl'
type:
  'laptop'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  'Chip 2.0 present but Coreboot not yet able to make use of it.'
remap:
  'yes'
brand: |
  Star Labs
model: |
  StarBook MK V
bios: |
  'Coreboot 7.91'
cpu: |
  '11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz'
cpu-short: |
  i7-1165G7
chipset: |
  'Intel Corporation 11th Gen Core Processor Host Bridge/DRAM Registers [8086:9a14] (rev 01)'
chipset-short: |
gpu: |
  'Intel Corporation TigerLake-LP GT2 [Iris Xe Graphics] [8086:9a49] (rev 01) (prog-if 00 [VGA controller])'
gpu-short: |
  'Iris Xe'
network: |
  'Realtek RTL8153 for Ethernet, Intel Corp Wi-Fi 6 AX201 (rev 20) for WIFI'
memory: |
  32613
scsi: |
  'Gen4 PCIe (500GB OP SSD)'
usb: |
  2
versions:
- works:
    'yes'
  qubes: |
    R4.1-rc4
  xen: |
    4.14.3
  kernel: |
    5.10.76-1
  remark: |
  'R4.0.4 Installation Failed: (black screen) Likely issue #6704 in qubes-issues database.'
  'R4.1.0-rc4 Installed properly.'
  'Internet connections via Ethernet and WiFi work properly.  It took an embarrassing amount of time to realize the Ethernet connection required the use of sys-usb. Select via Device Manager applet in toolbar.'
  'Hardware related functions I personally tested: power-on, power-off, suspend, display, keyboard, touch-pad, sound, 3 of 3 USB ports, micro SD card port read and write, HDMI audio and video.'
  'Also verified ability to create, modify, delete, update and backup individual qubes.'
  credit: |
    MrLeery
  link: |
    MrLeery
Remarks
  • R4.0.4 Installation Failed: (black screen) Likely issue #6704 listed in qubes-issues database.
  • R4.1.0-rc4 Installed properly.
  • Internet connections via wired Ethernet and WiFi work properly, though it took an embarrassing amount of time to realize the Ethernet connection required the use of sys-usb on my machine. Select via Device Manager applet in the toolbar.
  • Hardware related functions I personally tested: power-on, power-off, suspend, display, keyboard, touch-pad, sound, 3 of 3 USB ports, micro SD card port read and write operations, HDMI audio and video. Also verified ability to create, modify, delete, update and backup individual qubes.
Thank you @MrLeery for your HCL report, which is online now.
