Is it possible to connect a standaloneVM to an appVm like whonix Gateway? It works fine with the default firewallVM
Yes, just change the netvm.
You may need to manually adjust the IP settings in the standaloneVM
Hi. I tried this and copied the network settings into the VM manually and it still wouldn’t connect for some reason. It works fine with the firewall VM but not with the Whonix GW VM
