Standalone VM freezes after desktop loads after changing screen dimensions
I installed a standalone Debian VM and when it’s set to default 4:3 1024x768 it runs fine, but once I update the dimensions to 1920x1080 it freezes up as soon as the desktop loads after a reboot and does not respond to anything other than the shutdown command from outside the OS, on which it shuts down normally. It will not respond at all after any boot.
Qubes itself runs slightly higher than 1920x1080, but resetting it to 1920x1080 does not resolve the problem.
Any ideas? Thank you.
Create a new Debian standaloneVM and attempt to use that instead.
This works but I’m still wondering what the problem could be with the standalone. Maybe not enough RAM?
Provide your hardware configuration.
