Standalone HVM Arch Qube Boot Problems
So I finally got network running on my Arch Iso, and did all the steps on how to install arch etc, making lvms on /dev/xvdb1. I installed Grub and configured it and it all went smoothly, now when I restarted it to see if it would reboot back to the Arch Linux terminal, I get a SeaBIOS error saying “Boot failed: not a bootable disk” and “Boot failed: could not read the boot disk”, “No bootable device.”. I have tried running the qube without a kernel via dom0 command line, however I still get the same result. I’m not sure how to make the SeaBios detect my non-uefi grub installation. Any help would be much appreciated, as I feel like I’m finally close to the end of making a standalone HVM Arch qube derived from the original iso.
I haven’t had these issues myself, but invariable I install to xvda,
rather than xvdb. Was there some reason why you chose this?
Where did you install grub?
How did you configure it?
Did you fixed your problem? Because i have a same problem like you
Do you mean that you installed to /dev/xvdb and are not able to boot?
Why did you do this?
I mean i trying to install a blackarch linux from iso image and i installed them firstly to /dev/xvda but it’s didn’t work and i trying to install them to /dev/xvdb but it also didn’t work
If you can please check my topic i describe my problem in them
“didnt work” is profoundly unhelful
i will check - in the meantime I provide a blackarch template at
3isec
