Probably a very noobish question but:
Is it possible to create VMs that run standalone (as it was a different pc) with the option to have passthrough of PCI(e) devices and usb?
- I would like to be able to run a server in a separate environment in a container and VM
- to be able to have VM with its own screen and usb input that can function as a separate PC
I currently run Proxmox for that by which one VM is the ‘main’ PC, another VM is the ‘second’ PC and a LXC container is running the server. If possible I would like to run the main PC in the cubes OS and there create the VM for the second pc and create the container.
thank you.
