Ssh to dom0
hi, i looked around and searched for threads but didn’t find anything too relevant (not interested in vnc or rdp)
can i setup ssh to dom0 from LAN, then use salt or qvm-run to manage appvms from dom0? i don’t need GUI, but shell is nice (qvm-run -p APPVM bash might not be best experience)
how risky is this? there are no targeted attacks, will only be used on small home network, i suppose it is as safe as ssh is and the appvm connecting?
and i will ssh from another qubes machine from a trusted appvm
is it supported and is there maybe community guide to set it up?
dom0 is not connected to network. Unless you disable sys-net and sys-firewall and make dom0 as network service for all qubes.
what about qvm-connect-tcp?
Since you are breaking the security model. Why not use something more comfortable as a network VM host like proxmox?
This would probably be the way, but it really is hardly worth it to increase your attack surface so significantly.
You would do better to set up an admin qube, and ssh in to that.
This would give you better control over what is exposed to the network,
and what capabilities are available there, while minimising the major
risk in exposing dom0.
The capability for this was first detailed almost 10 years ago, but is
still little known. Read the original post here
@unman
What is the difference between admin qube and dom0? This is the first time I read there can be a second admin VM.
You can use policies to restrict the admin qube to be able to do only a subset of operations on specific qubes.
Sure. But it is impossible to qvm-prefs my-admin-qube klass AdminVM, so I was confused if he meant something like a second dom0 or anything else.
I don’t think it is possible to have a second dom0 with current xen: Dom0 - Xen
Does it mean that adminvm is a domu with a tap into xen control mechanism? Kind of like root vs sudoer?
… and I think I confused the “admin qube” with a “management qube”.
Thanks to you and @qubist for confirming that this is a sadly neglected
feature of Qubes. I provided a link to the first description in my post.
It is not possible to have a second dom0. It is possible to have a
second/third/fourth admin qube. This is a qube that you create and which
you configure to be able to manage and control aspects of your Qubes
system. These qubes are not of KLASS AdminVM.
This is not necessarily the same as a management qube. Check the
glossary. (The original new post was not clear about this.)
Once you have set up such a qube, you can access it from the network.
You specify in policy files what qubes you want to control, and exactly
what you want to be able to do with them. (At one end would be complete
control and access to all qubes on the system, at another, limited
access to a single qube.)
Naturally, you do not need to make the admin qube externally available
at all. This is useful when working with new salt or ansible features
that are not yet ready for deployment in dom0.
@unman
What about e.g. a service running in dom0 that monitors for specific requests generated by the “admin qube” and executing them? Seems simpler to me (assuming one can write the short scripts about it). It can be as simple as a text file in the “admin qube” that dom0 reads periodically.
Speaking of all that, can you explain or show a link to explanation how exactly dom0 is made network-less?
I don’t know what you mean by that, but maybe reverse order of this:
#enabling-network-access-in-dom0
@quber
Well, it doesn’t really answer my question but perhaps answers the OP in one more way. :slight_smile:
according to Provide a maintained OpenSSH package in dom0 for those who manually install it · Issue #7493 · QubesOS/qubes-issues · GitHub and GitHub - QubesOS/qubes-openssh: Packaging of openssh · GitHub it should be possible to install openssh-server in dom0, then use qvm-connect-tcp from sys-net to dom0.
i will try later, this machine is not so important, and worst case the dom0 should be no more vulnerable than openssh-server and the appvm which i connect from
the appvm i trust, openssh-server too, and no one on my network will attack (can even just allow the other qubes machine to connect)
You can do this, and you appear to accept any risk.
In my opinion it’s a mistake, and not to be encouraged.
Isn’t this what qrexec-daemon is? Unless I misunderstood what you mean
I have not looked at the code of qrexec-daemon, so I can’t say what it does but I doubt it monitors for any separate/second “admin qube” since one does not exist in default Qubes.
I don’t think it would matter for the daemons as they (1 for each qube) are supposed to handle all qrexec calls. If admin qube (functionally admin, not of class admin) uses qrexec (with default qubes-core-admin-client it does), all admin calls should eventually go through a qrexec daemon:
An exception are calls made by dom0, e.g. qubes-core-admin-client tools with app of class QubesLocal (calling local qubesd socket). They bypass the qrexec part of the diagram and speak the elusive qubes socket API directly. I think. Or I may be mistaken and they just use a weird dom0-specific version of admin API that always sends source (just string “dom0”) as well as destination.
If you mean qube of class AdminVM though, I don’t know… I don’t have a mental image of what non-dom0 AdminVM is or whether it is even possible. For example, if we have a second AdminVM, does it mean it is not domU? According to xen it can’t be that. But then does it mean dom0 is running qrexec daemon instance for that qube? Doesn’t this make it just a normal qube?
Hopefully somebody could clarify this.
