I installed sys-vpn from the unamn repository [1], and everything works smoothly. However, I need this setup [2]: I need to connect to an SSH server in sys-vpn. All I need is an nftables rule that allows sys-vpn to connect to the SSH IP. Previously, I used this rule [3] with this setup [4]. Can anybody help write a rule that opens a hole in the firewall rules to enable SSH access in sys-vpn [1]?
