Spotify icon not working on debian 11
I followed directions to download spotify onto qube os.
The last few lines creates a desktop entry. I added Spotify in the Qubes Settings to show up on the menu for the AppVM. But on selecting it, all i get is a black window - no terminal, no gui.
How can i start the spotify gui in my appvm.
Does it start from the terminal? Maybe it shows any errors there?
just set up --disable-gpu, because its an electron app.
“I added Spotify to the Qubes Settings so it appears in the AppVM menu, but when I click it, only a black window shows up—no terminal, no GUI. How can I launch the Spotify interface in my AppVM?”
You have tried to open from the terminal? Just open a terminal of your AppVM and run spotify &
Hi @kingiotai and welcome here! Could you try to follow the following instructions?
Then tell us the outcome :slight_smile:
