Split-gpg2: NotImplementedError
I’m setting up split-gpg2 and seemingly have it working in that a client VM can run gpg --list-secret-keys and it will return my key.
Great! However, in my server VM I see this pop out of journalctl -f each time I run gpg --list-secret-keys in a client:
servervm qubes.Gpg2+-clientvm[1120]: Traceback (most recent call last):
servervm qubes.Gpg2+-clientvm[1120]:   File "<frozen runpy>", line 198, in _run_module_as_main
servervm qubes.Gpg2+-clientvm[1120]:   File "<frozen runpy>", line 88, in _run_code
servervm qubes.Gpg2+-clientvm[1120]:   File "/usr/lib/python3/dist-packages/splitgpg2/__main__.py", line 3, in <module>
servervm qubes.Gpg2+-clientvm[1120]:     main()
servervm qubes.Gpg2+-clientvm[1120]:   File "/usr/lib/python3/dist-packages/splitgpg2/__init__.py", line 1457, in main
servervm qubes.Gpg2+-clientvm[1120]:     loop.run_until_complete(server.run())
servervm qubes.Gpg2+-clientvm[1120]:   File "/usr/lib/python3.11/asyncio/base_events.py", line 653, in run_until_complete
servervm qubes.Gpg2+-clientvm[1120]:     return future.result()
servervm qubes.Gpg2+-clientvm[1120]:            ^^^^^^^^^^^^^^^
servervm qubes.Gpg2+-clientvm[1120]:   File "/usr/lib/python3/dist-packages/splitgpg2/__init__.py", line 426, in run
servervm qubes.Gpg2+-clientvm[1120]:     await self.client_writer.wait_closed()
servervm qubes.Gpg2+-clientvm[1120]:   File "/usr/lib/python3.11/asyncio/streams.py", line 350, in wait_closed
servervm qubes.Gpg2+-clientvm[1120]:     await self._protocol._get_close_waiter(self)
servervm qubes.Gpg2+-clientvm[1120]:           ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
servervm qubes.Gpg2+-clientvm[1120]:   File "/usr/lib/python3.11/asyncio/streams.py", line 178, in _get_close_waiter
servervm qubes.Gpg2+-clientvm[1120]:     raise NotImplementedError
servervm qubes.Gpg2+-clientvm[1120]: NotImplementedError
If you are using split-gpg2, do you see this in your server VM journal also?
For posterity: I opened an issue for this:
I tested it with qubes-gpg-client --list-secret-keys and it works fine for me. Also no scary log message… strange…
Thanks, that is interesting. If you don’t mind sharing, what base template do you use for the vault?
nothing either, I’m using a fedora-39 for both the gpg client and the gpg vault
Thanks. It’ll be a little while before I can look into this again but next I’ll try to reproduce the logging w/ a Fedora template.
my template is debian 12, also for both
