On my laptop as well as that of a colleague, Split GPG is freezing Thunderbird once every 20 times we use it on average. It’s hindering our work. The only solution is to shutdown the work VM and restart it or to kill Thunderbird. And restart.
This is happening for work VM in Debian or in Fedora, and the vault-gpg VM in Fedora.
Is anyone else facing this problem? Is there a solution? Thank you.
A third person using Qubes on a third machine model (all thinkpads - different models) told me he is facing the same problem. Regular freezing of Thunderbird because of SplitPGP. Is anyone else facing such problems?
I think this may need to be officially reported as a bug. Tried looking there but found nothing. So it’s likely this hasn’t yet caught the developer’s eyes.
I’m not sure how those logs can be found. Generally if you don’t know where to find the logs with a quick search, it’s ok. The developers will point you in the right direction to provide those. The most important thing is for issues to be reported so the developers are aware (even if not all answers having been found).
