Split-Browser Bookmarks, Logins & Browsers
Good tip - I updated my list to make it simpler.
Last question: There are 2 different split browser options, ‘Split Browser’ and ‘Split Browser (TB Security Level: Safest)’. What is the difference between these options? Are they both relevant when using Tor and Mullvad? Thanks again.
It’s this:
SECURITY SETTINGS | Tor Project | Tor Browser Manual (applies to Mullvad Browser too):
Safest
  • This level only allows website features required for static sites and basic services. These changes affect images, media, and scripts.
  • Javascript is disabled by default on all sites; some fonts, icons, math symbols, and images are disabled; audio and video (HTML5 media) are click-to-play.
How we can customize bookmark window? Default size, colors and especially font and its size?
Thanks.
Check out the sb_dmenu() configuration in /etc/split-browser/ on the persistent side. Despite the name dmenu, it’s actually calling rofi at the moment (as a temporary-ish workaround for a glitch). rofi can be themed, take a look at its manpage.
Thanks! I prefer that Monokai rofi theme.
Is there, and when not, when split-browser will be available for fedora-44 templates?
It’s in the current-testing repo: app-split-browser v0.17.5 (r4.3) · Issue #96 · QubesOS-contrib/updates-status · GitHub
I have upgraded inplace librewolf template to f44 and I can confirm it works - I’m getting bookmarks on ALT+B. Still to upgrade splite-browse tempate to f44.
Thanks.
