Here’s an output of alsa-info.sh
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.65
!!Script ran on:
!!Linux Distribution
!!DMI Information
Manufacturer: To Be Filled By O.E.M.
Product Name: To Be Filled By O.E.M.
Product Version: To Be Filled By O.E.M.
Firmware Version: P1.00
System SKU: To Be Filled By O.E.M.
Board Vendor: ASRock
Board Name: H370M-ITX/ac
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI000C:00/status 15
/sys/bus/acpi/devices/INT33A1:00/status 15
/sys/bus/acpi/devices/INT3450:00/status 15
/sys/bus/acpi/devices/INT3F0D:00/status 15
/sys/bus/acpi/devices/LNXPOWER:00/status 1
/sys/bus/acpi/devices/LNXPOWER:01/status 1
/sys/bus/acpi/devices/LNXPOWER:02/status 15
/sys/bus/acpi/devices/LNXPOWER:03/status 1
/sys/bus/acpi/devices/LNXPOWER:04/status 1
/sys/bus/acpi/devices/LNXPOWER:05/status 1
/sys/bus/acpi/devices/LNXPOWER:06/status 1
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0303:00/status 15
/sys/bus/acpi/devices/PNP0C02:03/status 3
/sys/bus/acpi/devices/PNP0C02:05/status 3
/sys/bus/acpi/devices/PNP0C04:00/status 31
/sys/bus/acpi/devices/PNP0C0C:00/status 15
/sys/bus/acpi/devices/PNP0C0E:00/status 11
/sys/bus/acpi/devices/PNP0C0F:00/status 11
/sys/bus/acpi/devices/PNP0C0F:01/status 11
/sys/bus/acpi/devices/PNP0C0F:02/status 11
/sys/bus/acpi/devices/PNP0C0F:03/status 11
/sys/bus/acpi/devices/PNP0C0F:04/status 11
/sys/bus/acpi/devices/PNP0C0F:05/status 11
/sys/bus/acpi/devices/PNP0C0F:06/status 11
/sys/bus/acpi/devices/PNP0C0F:07/status 11
/sys/bus/acpi/devices/PNP0F03:00/status 15
/sys/bus/acpi/devices/PRP00001:00/status 11
!!Kernel Information
Kernel release: 5.15.94-1.qubes.fc32.x86_64
Operating System: GNU/Linux
Architecture: x86_64
Processor: x86_64
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.15.94-1.qubes.fc32.x86_64
Library version:
Utilities version: 1.2.4
!!Loaded ALSA modules
snd_hda_intel
!!Sound Servers on this system
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
!!Soundcards recognised by ALSA
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0xa1330000 irq 164
!!PCI Soundcards installed in the system
00:1f.3 Audio device [0403]: Intel Corporation Cannon Lake PCH cAVS [8086:a348] (rev 10)
DeviceName: Onboard - Sound
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 1
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
!!ALSA Device nodes
crw-rw----+ 1 root audio 116, 2 Mar 12 10:53 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 1 Mar 12 10:53 /dev/snd/seq
crw-rw----+ 1 root audio 116, 33 Mar 12 10:53 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 60 Mar 12 10:53 .
drwxr-xr-x 3 root root 120 Mar 12 10:53 ..
lrwxrwxrwx 1 root root 12 Mar 12 10:53 pci-0000:00:1f.3 -> ../controlC0
!!ALSA configuration files
!!System wide config file (/etc/asound.conf)
# Place your global alsa-lib configuration here...
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
ARECORD
**** List of CAPTURE Hardware Devices ****
!!Amixer output
!!-------Mixer controls for card PCH
Card hw:0 'PCH'/'HDA Intel PCH at 0xa1330000 irq 164'
Mixer name : ''
Components : ''
Controls : 1
Simple ctrls : 1
Simple mixer control 'PCM',0
Capabilities: pvolume
Playback channels: Front Left - Front Right
Limits: Playback 0 - 255
Mono:
Front Left: Playback 254 [100%] [-0.20dB]
Front Right: Playback 254 [100%] [-0.20dB]
!!Alsactl output
--startcollapse--
state.PCH {
control.1 {
iface MIXER
name 'PCM Playback Volume'
value.0 254
value.1 254
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 -20
dbvalue.1 -20
--endcollapse--
!!All Loaded Modules
ac97_bus
asn1_encoder
cec
cfg80211
crc32_pclmul
crc32c_intel
crct10dif_pclmul
dca
dm_bio_prison
dm_crypt
dm_persistent_data
dm_thin_pool
drm
drm_kms_helper
e1000e
ee1004
fuse
ghash_clmulni_intel
hwmon_vid
i2c_algo_bit
i2c_i801
i2c_smbus
i915
iTCO_vendor_support
iTCO_wdt
igb
intel_pch_thermal
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
ip_tables
iwlwifi
ledtrig_audio
loop
mei
mei_hdcp
mei_me
nct6775
pcspkr
pinctrl_cannonlake
rfkill
serio_raw
snd
snd_compress
snd_hda_codec
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_pcm_dmaengine
snd_seq
snd_seq_device
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_hdac_hda
snd_soc_skl
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_sof
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_pci
snd_sof_pci_intel_cnl
snd_sof_xtensa_dsp
snd_timer
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
trusted
ttm
uinput
video
wmi
wmi_bmof
xen_acpi_processor
xen_blkback
xen_evtchn
xen_gntalloc
xen_gntdev
xen_pciback
xen_privcmd
xenfs
xhci_hcd
xhci_pci
xhci_pci_renesas
!!ALSA/HDA dmesg
[ 2.672957] ACPI: Added _OSI(Linux-Dell-Video)
[ 2.672958] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 2.672960] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 34.254016] Already setup the GSI :16
[ 34.254070] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 34.258472] snd_hda_intel 0000:00:1f.3: Unknown capability 0
[ 34.365444] snd_hda_intel 0000:00:1f.3: CORB reset timeout#1, CORBRP = 0
[ 34.366888] snd_hda_intel 0000:00:1f.3: no codecs found!
[ 35.099977] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: discard. Quota mode: none.
!!Packages installed
alsa-utils-1.2.4-2.fc32.x86_64
alsa-lib-1.2.4-5.fc32.x86_64
alsa-sof-firmware-2.1.1-1.fc32.noarch
Anything else I can try? Any more diagnostics I can do?
Ok, this is weird
this are my logs related to snd_hda_intel
Mar 08 02:28:19 dom0 kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Mar 08 02:34:13 dom0 pulseaudio[4641]: Most likely this is a bug in the ALSA driver 'snd_hda_intel'. Please report this issue to the ALSA developers.
Mar 12 02:10:22 dom0 kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Mar 12 02:10:22 dom0 kernel: snd_hda_intel 0000:00:1f.3: Unknown capability 0
Mar 12 02:10:22 dom0 kernel: snd_hda_intel 0000:00:1f.3: CORB reset timeout#1, CORBRP = 0
Mar 12 02:10:22 dom0 kernel: snd_hda_intel 0000:00:1f.3: no codecs found!
Mar 12 02:41:42 dom0 kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Mar 12 02:41:42 dom0 kernel: snd_hda_intel 0000:00:1f.3: Unknown capability 0
Mar 12 02:41:42 dom0 kernel: snd_hda_intel 0000:00:1f.3: CORB reset timeout#1, CORBRP = 0
Mar 12 02:41:42 dom0 kernel: snd_hda_intel 0000:00:1f.3: no codecs found!
Mar 12 10:53:28 dom0 kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Mar 12 10:53:28 dom0 kernel: snd_hda_intel 0000:00:1f.3: Unknown capability 0
Mar 12 10:53:28 dom0 kernel: snd_hda_intel 0000:00:1f.3: CORB reset timeout#1, CORBRP = 0
Mar 12 10:53:28 dom0 kernel: snd_hda_intel 0000:00:1f.3: no codecs found!
I maybe didn’t reboot my machine since the eight of March so maybe that bug is the cause… but what could’ve triggered it? Every time I update dom0 I reboot to check if everything is working, and everything worked since my last update.
Also the last dom0 update related to sound was on 28 February when qubes-audio-daemon and qubes-audio-dom0 were updated.
My last update was on 08 March that updated a bunch of xen packages.
That last update on 08 March was at 1:30 and that alsa bug got triggered at 2:30, but again there were updated only xen related packages… could a xen related package trigger an alsa bug?
