I have a Sony USB webcam that I was using without any problems under Q4.1, but after the upgrade to 4.2 it has no audio. The video works just fine but I can’t for the life of me figure out how to get the microphone to give any visible audio level. Only once was I able to get Zoom to cooperate but Teams Meeting (Using Edge browser) isn’t playing nice, and that’s what I need it for. Sound recorder also sees no input as well.
Using pulse audio volume control shows no signal at all, so its not a volume issue. There doesn’t seem to be any input device to set it to that will show that there is any input signal coming from the device. It’s plugged into sys-usb and then passed to the AppVM, and this used to work find without playing with any settings, but now it doesn’t. Even trying it in sys-usb directly it doesn’t appear to work. I’m looking for ideas on where to look.
I had to host a meeting tonight and could not for the life of me figure out how to get it to work. I had to use an old laptop instead.
