I downloaded debian 12 minimal and tried to install wget but it fails to fetch:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following additional packages will be installed:
libpsl5 publicsuffix
The following NEW packages will be installed:
libpsl5 publicsuffix wget
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 1122 kB of archives.
After this operation, 4051 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Ign:1 https://deb.debian.org/debian bookworm/main amd64 libpsl5 amd64 0.21.2-1
Ign:2 https://deb.debian.org/debian bookworm/main amd64 wget amd64 1.21.3-1+deb12u1
Ign:3 https://deb.debian.org/debian bookworm/main amd64 publicsuffix all 20230209.2326-1
Err:1 https://deb.debian.org/debian bookworm/main amd64 libpsl5 amd64 0.21.2-1
Temporary failure resolving 'deb.debian.org'
Err:2 https://deb.debian.org/debian bookworm/main amd64 wget amd64 1.21.3-1+deb12u1
Err:3 https://deb.debian.org/debian bookworm/main amd64 publicsuffix all 20230209.2326-1
E: Failed to fetch https://deb.debian.org/debian/pool/main/libp/libpsl/libpsl5_0.21.2-1_amd64.deb Temporary failure resolving 'deb.debian.org'
E: Failed to fetch https://deb.debian.org/debian/pool/main/w/wget/wget_1.21.3-1%2bdeb12u1_amd64.deb Temporary failure resolving 'deb.debian.org'
E: Failed to fetch https://deb.debian.org/debian/pool/main/p/publicsuffix/publicsuffix_20230209.2326-1_all.deb Temporary failure resolving 'deb.debian.org'
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
apt-get update
Ign:1 https://deb.debian.org/debian bookworm InRelease
Ign:2 https://deb.qubes-os.org/r4.3/vm bookworm InRelease
Ign:3 https://deb.debian.org/debian-security bookworm-security InRelease
Ign:4 https://deb.debian.org/debian bookworm-backports InRelease
Err:2 https://deb.qubes-os.org/r4.3/vm bookworm InRelease
Temporary failure resolving 'deb.qubes-os.org'
Err:1 https://deb.debian.org/debian bookworm InRelease
Err:3 https://deb.debian.org/debian-security bookworm-security InRelease
Err:4 https://deb.debian.org/debian bookworm-backports InRelease
E: Failed to fetch https://deb.debian.org/debian/dists/bookworm/InRelease Temporary failure resolving 'deb.debian.org'
E: Failed to fetch https://deb.debian.org/debian-security/dists/bookworm-security/InRelease Temporary failure resolving 'deb.debian.org'
E: Failed to fetch https://deb.debian.org/debian/dists/bookworm-backports/InRelease Temporary failure resolving 'deb.debian.org'
E: Failed to fetch https://deb.qubes-os.org/r4.3/vm/dists/bookworm/InRelease Temporary failure resolving 'deb.qubes-os.org'
E: Some index files failed to download. They have been ignored, or old ones used instead.
