Playing around with appearance and trying to set things “visually” as easy as possible to my eyes, I have noticed some issues during so, not sure if these are bugs.
1- Qube Manager, View => compact
I have to do it every time I close it and reopen it.
2- Appearance - dark mode.
Icons "Task icons at top: Shutdown - Restart…etc " in Qube Manager are changed to dark too, not possible to see them, I have to hover the mouse and wait for tips to show up, as well, Can I download any XFCE theme and apply it or I will have some Qubes coloring or theming issues?
3- Windows always open too big on my screen where I have to adjust them every time I open them, I couldn’t fix this from XFCE settings or whatever.
4- As of documentation, I tried to install i3 on Dom0 and restarted, the interface was like a miss and windows were showing content from other windows, like a screenshot stuck on half of the screen.
5- Adding notification for panel top right, it disappears after restarting, as well, any settings I have changed " like keep logs to 1000 - no logs at all".
6- Open Global Config GUI and moving around without changing any settings, keep showing me if I would like to save or discard changes, esp at updates.
Yes I now this is strange and I don’t think it’s common, but wanted to share it, things like work then don’t then ok, so strange. '1 n 2 ’
2- Thanks for the link I will check it out.
4- It was on X installaion of Qubes, I took a note next time I try do i3.
5- The notification plugin on panel, seems like ok now and always showing there but still doesn’t keep the notifications.
6- First time Qubes Os run, open “Qube Global Config” and it will ask you to save while moving around tab without changing anything.
