Some ACPI and qrexec-policy-daemon errors at boot
I just did a fresh install of Qubes 4.3 and I have errors at startup (just before entering the disk password:
déc. 28 15:09:39 dom0 qmemmand[3186]: xen.lowlevel.xs.Error: (22, ‘Invalid argument’)
déc. 28 15:12:11 dom0 kernel: ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [CAP1] at bit offset/length 64/32 exceeds size of target Buffer (64 bits) (20250404/dsopcode-198)
déc. 28 15:12:11 dom0 kernel: ACPI Error: Aborting method _SB._OSC due to previous error (AE_AML_BUFFER_LIMIT) (20250404/psparse-529)
déc. 28 15:12:11 dom0 kernel: ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x000000005) is beyond end of object (length 0x5) (20250404/exoparg2-393)
déc. 28 15:12:11 dom0 kernel: ACPI Error: Aborting method _TZ.GETP due to previous error (AE_AML_PACKAGE_LIMIT) (20250404/psparse-529)
déc. 28 15:12:11 dom0 kernel: ACPI Error: Aborting method _TZ.CHGZ._CRT due to previous error (AE_AML_PACKAGE_LIMIT) (20250404/psparse-529)
déc. 28 15:12:11 dom0 kernel: RAS: Correctable Errors collector initialized.
then when I enter my session:
`déc. 28 15:15:28 dom0 qrexec-policy-daemon[7198]: FileNotFoundError: [Errno 2] No such file or directory
déc. 28 15:16:17 dom0 qubesd[6760]: raise libvirtError(‘virDomainAttachDevice() failed’)
déc. 28 15:16:17 dom0 qubesd[6760]: libvirt.libvirtError: argument non valide : Le périphérique réseau avec le mac 00:16:3e:5e:6c:00 existe déjà
Despite this error, the system is stable but I wonder because I didn’t have these errors with version 4.2.4.
Is this a mistake to be taken seriously? Has anyone met him too and knows how to solve them?
Edit: with the command sudo qrexec-policy-daemon i had:
warning: !compat-4.0 directive in file /etc/qubes/policy.d/35-compat.policy line 16 is transitional and will be depreciate
qrexec: sdwdate-gui.ConnectCheck: sys-net -> sys-whonix: denied by policy /etc/qubes/policy.d/80-whonix.policy:10
In the past, updating my BIOS has helped with ACPI errors. Are you running the latest one?
i checked that but it’s the latest version of bios.
I give up the trouble. it doesn’t seem to cause any problems in the use of qubes-os :slight_smile:
