SOLVED: Varlibqubes is 99.5% full after installing and migrating Qubes to 4.3
I wiped my main machine and installed Q4.3. I imported all of my Qubes (about 1TB worth, about 170 Qubes). The drive is a 2TB drive. Total disk usage reads 57%.
qvm-pool list shows
NAME		DRIVER
varlibqubes	file
linux-kernel	linux-kernel
vm-pool		lvm_thin
qvm-pool info vm-pool shows:
name				vm-pool
driver				lvm_thin
ephemeral_volatile	False
revisions_to_keep	2
size				1775948005376
thin_pool			vm-pool
usage				1015131879872
volume_group		qubes_dom0
For a qube I imported, qvm-volume list <oldQube> shows:
POOL:VOLUME
vm-pool:qubes_dom0/vm-......
But for a Qube I’ve created since the new install, it shows:
POOL:VOLUME
varlibqubes:appvms/QubeName/private
So I think this is the source of the problem, but I’m not sure what I did wrong to make this happen. Can anyone tell me and hopefully how to fix it?
du -h in /var/lib/qubes shows 14G.
The warning triangle in the upper-right of the XFCE top bar shows varlibqubes “data” is at 99.6% or 19.4GiB/19.5Gib
Possible related? I notice that I get a memory warning when opening several Qubes. I didn’t run into this with Q4.2 at the same number of open Qubes. 32GB RAM on the machine, and it’s been my reliable working machine for some time. Of course I don’t know if that problem is related.
Any ideas where to start troubleshooting or how to fix this?
Thank you.
Figured it out. When I created a Qube, I must have accidentally set it to use varlibqubes instead of the default _vm_pool) and it was a large Qube, so it brought me to 99.5%. I don’t understand the whole varlibqubes thing, and I can’t find good documentation, so that’s annoying. But anyway it’s fixed.
