I’m using a sys-dns as described here and it works fine in most situations.
However, in hotel wifis or other wifis which enforce a captive portal I have trouble reaching the captive portal.
[user@sys-dns]~% cat /etc/dnscrypt-proxy/captive-portals.txt
# Captive portal test names #
## [stuff]
captiveportal.somehotel.org 107.201.79.65
## [stuff]
captive.apple.com 17.253.109.201, 17.253.113.202
## [stuff]
[root@sys-dns]~% ss -tunlp
Netid State Recv-Q Send-Q Local Address:Port Peer Address:Port Process
udp UNCONN 0 0 127.0.0.1:53 0.0.0.0:* users:(("dnscrypt-proxy",pid=566,fd=7))
tcp LISTEN 0 4096 127.0.0.1:53 0.0.0.0:* users:(("dnscrypt-proxy",pid=566,fd=8))
[root@sys-dns]~% iptables -L -t nat
Chain PREROUTING (policy ACCEPT)
target prot opt source destination
PR-QBS all -- anywhere anywhere
PR-QBS-SERVICES all -- anywhere anywhere
Chain INPUT (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Chain POSTROUTING (policy ACCEPT)
ACCEPT all -- anywhere anywhere
MASQUERADE all -- anywhere anywhere
Chain PR-QBS (1 references)
## output of iptables stops at this point
## iptables does not finish but hangs
At this point of time there is no connectivity because I haven’t authenticated at the captive portal yet. dnscrypt-proxy is listening for a minute or maybe two, then shuts down.
However, since iptables does not redirect dns-requests, a web-redirect from http://1.1.1.1 to http://captiveportal.somehotel.org does not finish as the dns-request for captiveportal.somehotel.org is not resolved.
From my point of view this is not a dnscrypt-proxy issue, it might be an iptables-issue, but I suspect it to be a qubes-issue or the way Qubes implement iptables-rules.
Anyone an idea why iptables does not DNAT/redirect my dns-requests at that point of time?
