[solved] loosing whonix connectivity (whonix-gw-16)
My whonix-gw-16 looses connectivity after an hour or so of running.
For trouble shooting I’ve run
sudo apt update
whonix | less
sudo journalctl -b
sdwate log viewer (via whonix-control-panel)
read
Troubleshooting - Whonix
and read various threads here in this forum (“whonix-gw freezes” and so forth).
However foramentioned log-files haven’t provided much of a clue to me so far.
Maybe the uplink breaks… I do use obfs4 bridges… can someone with more experience (or the same issues) give me a little guidance on debugging.
I have the same issue with bridges sometimes and have to restart tor in sys-whonix and after reconnect it works again.
I guess it’s just a bridge problem.
The whonix troubleshooting guide is mentioning the bridges as a source of connectivity issues, too.
I will keep open
journalctl -f
and update this post in case I am able to catch a promising output.
[timestamp] host vanguards[787]: WARNING[timestamp]: We've been disconnected from the Tor network for 15 seconds!
shows up in the journal and it gets a new warning every 15 seconds. That isn’t elaborating why, but as you said, restarting Tor in sys-shonix helps.
