Conclusion at bottom
Hardware: Lenovo ThinkPad P51, Intel Xeon E3-1505M v6, Intel PCH ALC298 audio codec, NVIDIA GM206 HD Audio controller.
Operating systems tested:
- Qubes OS 4.3.1 — PipeWire 1.2.8, WirePlumber 0.5.11 in dom0
- Ubuntu 20.04.2 — PulseAudio 13.99.1
- Ubuntu 24.04 — PipeWire 1.0.5, WirePlumber 0.4.17 (also tested with PulseAudio 16.1)
Problem
I spent considerable time investigating serious audio problems on my Lenovo ThinkPad P51.
The symptoms varied depending on the Linux distribution and audio subsystem.
Qubes OS 4.3.1:
- WirePlumber in dom0 consistently consumed approximately 97–99% of one CPU core.
- Audio-related operations were sometimes unresponsive.
- Debian 13 AppVMs (
personalandwork) displayed only “Dummy Output” instead of the expected Qubes Virtual Audio Sink. - Applications in those qubes could not play sound.
- The physical laptop speakers worked when tested directly through ALSA in dom0, suggesting the hardware itself was functional.
Ubuntu 20.04.2:
- The Sound Settings input-device display flashed or refreshed continuously.
pactl list short source-outputs | wc -lreturned 257.- GNOME Control Center was generating hundreds of microphone-related streams and consuming substantial CPU.
pactl subscribeshowed continuous card/source change events, even after Sound Settings was closed.
Ubuntu 24.04:
- Audio subsystem instability was also investigated, including testing with PulseAudio and PipeWire/WirePlumber.
Discovery
In the ThinkPad P51 BIOS, under:
Security ? I/O Port Access ? Microphone
the microphone was set to Disabled.
I changed this setting to Enabled, leaving the camera disabled.
After rebooting, the audio problems disappeared.
Results after enabling the BIOS microphone
Ubuntu 20.04:
- The Sound Settings display stopped flashing.
- The source-output count dropped from 257 to 2.
- The continuous PulseAudio events stopped.
- CPU usage returned to normal.
Ubuntu 24.04:
- Sound Settings remained stable.
- No continuous audio events were observed.
- PipeWire and WirePlumber operated normally after restoring the PipeWire configuration.
- Speaker playback worked.
Qubes OS 4.3.1:
- WirePlumber CPU usage dropped from approximately 98% to 0.1%.
- dom0 detected the physical Built-in Audio Analog Stereo sink and source.
- Both
personalandworkdisplayed Qubes Virtual Audio Sink and Source instead of Dummy Output. - Sound playback worked in both AppVMs.
- The system was rebooted and retested on October 26, 2026.
- After reboot, WirePlumber remained at 0.1% CPU, PipeWire at 0.0%, and both left and right laptop speakers worked from
personal. - Audio routing for both
personalandworkremained present.
Conclusion
On this Lenovo ThinkPad P51, disabling the microphone in BIOS appears to trigger severe Linux audio subsystem problems affecting PulseAudio and PipeWire/WirePlumber.
Enabling the microphone in BIOS resolved the observed problems without requiring further Qubes audio configuration changes.
I have not identified the underlying kernel, ALSA, firmware, or audio-session-manager mechanism. The evidence establishes a strong relationship on this machine, but I have not performed a controlled disable/re-enable reproduction after discovering the fix.
For anyone experiencing unexplained WirePlumber CPU usage, continuously changing audio devices, or Dummy Output on similar Lenovo hardware, check the BIOS microphone setting before spending time rebuilding the audio configuration.
