I’m trying to use riot web snap in an App VM but I think the mount is failing for some reason. When I try to run riot-web sometimes it says
internal error, please report: running “riot-web” failed: cannot find installed snap “riot-web” at revision 96: missing file /var/lib/snapd/snap/riot-web/96/meta/snap.yaml
Then if I run df -h
I get
df: /run/user/1000/doc: Operation not permitted
Filesystem Size Used Avail Use% Mounted on
/dev/xvda3 9.6G 4.8G 4.3G 53% /
none 9.6G 4.8G 4.3G 53% /usr/lib/modules
devtmpfs 1.9G 0 1.9G 0% /dev
tmpfs 1.0G 11M 1014M 2% /dev/shm
tmpfs 1.7G 900K 1.7G 1% /run
/dev/xvdb 19G 1.2G 18G 7% /rw
tmpfs 1.0G 12K 1.0G 1% /tmp
/dev/loop0 15M 15M 0 100% /var/lib/snapd/snap/aws-cli/130
tmpfs 31M 552K 30M 2% /run/user/1000
/dev/loop1 56M 56M 0 100% /var/lib/snapd/snap/core18/1997
/dev/loop2 62M 62M 0 100% /var/lib/snapd/snap/core20/975
/dev/loop3 100M 100M 0 100% /var/lib/snapd/snap/core/10958
/dev/loop4 163M 163M 0 100% /var/lib/snapd/snap/gnome-3-28-1804/145
/dev/loop5 66M 66M 0 100% /var/lib/snapd/snap/gtk-common-themes/1515
/dev/loop6 75M 75M 0 100% /var/lib/snapd/snap/joplin/8
/dev/loop7 160M 160M 0 100% /var/lib/snapd/snap/signal-desktop/354
/dev/loop8 33M 33M 0 100% /var/lib/snapd/snap/snapd/11588
Seems like all the apps I’ve installed are there aside from riot-web.
This seems to happen sometimes but not all the time and can be fixed by restarting the AppVM most of the time.
