Hi, I have a major problem. My Qubes has become not usable since I updated dom0.
I can enter the decrytion password like normal. The user log in also works normally. But after I log in, I can only use the mouse for a second or so, before the computer shuts down (crashes) and reboots automatically. It literally only runs seconds.
The only error message is, before GRUB appears:
Error: file ‘/EFI/qubes/fonts/unicode.pf2’ not found.
This message has never appeared before, and the computer worked like a charm for months before now.
I’m in desperate need for help, as I really need to use this device.
EDIT: I had a continuing issue before, which I fixed by entering “x2apic=false” in the GRUB menu when booting, I’m still doing this.
