Simple way for Android USB debugging
I couldn’t find a simple guide on the forum for Android USB debugging.
  1. Install the packages needed for Android development in template. I’m using Fedora:
sudo dnf install android-tools
  1. In dom0:
Open qubes-policy-editor and create file 30-android.policy or run:
sudo nano /etc/qubes/policy.d/30-android.policy
Add:
#personal or other qube for Android connecting
qubes.ConnectTCP +5037 personal sys-usb ask default_target=sys-usb
  1. In sys-usb:
adb start-server
  1. Connect Android to the personal qube
  2. In personal (or other qube):
echo 4096 | sudo tee /sys/module/xen_gntalloc/parameters/limit
qvm-connect-tcp ::5037
adb devices
You will see this:
Binding TCP '@default:5037' to 'localhost:5037'...
List of devices attached
47142JEKC09172	unauthorized
  1. Then confirm and authorize the connection on your Android and check in personal qube:
adb devices
You will see this:
47142JEKC09172	device
Take a look at this guide:
Your way to deal with policies is deprecated since 2022 (R4.1), just follow the other guide or the official docs: How to edit a policy — Qubes OS Documentation
What is the purpose of this?
This could be a Public Service Announcement:
"Remember folks, if you don’t know exactly what it does, don’t type it into dom0, or anywhere else!
I have no idea what this xen_gntalloc parameter does, and I would therefore treat it with 100% suspicion.
