The procedure for shrinking a volume on Ext4 and most other filesystems is bit convoluted because online shrinking isn’t supported and we don’t want to process any untrusted data in dom0 for security reasons.
Shrinking volumes is dangerous and this is why it isn’t available in standard Qubes tools. If you have enough disk space, the recommended approach is to create a new VM with a smaller disk and move the data. However, this approach has two caveats:
- it requires copying data, which can take a while
- it is limited to the private volume of VMs based on TemplateVMs
ALWAYS BACKUP your data before attempting to shrink a volume..
Qubes 4.0 (root and private volumes)
Qubes 4.0 uses thin LVM storage: only the data present on a volume uses disk space, free space isn’t allocated physically. If your only concern is disk space, you may simply be careful with how much data you store in a given volume and avoid having to shrink a volume (use sudo lvs in dom0 and compare the LSize vs Data% fields to find out about real disk usage).
The instructions below show how to resize a Linux VM’s private volume. For root volumes, swap the -private volume suffix with -root. For other OSes (eg. MS Windows) you’ll have to use the OS’ specific tools to resize the volume at step 4 instead of resize2fs, and to be careful to specify the right shrinked size at step 6.
backup your data with
qvm-clone,qvm-backup, or your own backup mechanism. Do not rely only on snapshots (yet) -
stop the VM (eg. ‘largeVM’) whose volume has to be resized
start another VM (eg. ‘tempVM’) with largeVM’s private volume attached:
qvm-start --hddisk dom0:/dev/qubes_dom0/vm-largeVM-private tempVMAlternatively, you could setup a loop device in dom0 associated to largeVM’s private volume and attach it to a running VM but this is outside the scope of this document (see
losetupandqvm-block). -
in tempVM, resize the attached volume:
sudo e2fsck -f /dev/xvdi sudo resize2fs /dev/xvdi <newsize>(eg.
<newsize>=2G; seeman resize2fsfor allowed formats). -
shutdown tempVM
in dom0, resize the lvm volume to the SAME size you used at step 4. (specifying a lower size than the underlying filesystem’s size will corrupt the filesystem and either destroy some of your data or trigger filesystem exceptions when the filesystem tries to write at a location that doesn’t exist):
sudo lvresize -L<newsize> /dev/qubes_dom0/vm-largeVM-private
Qubes 3.2 (Linux VMs, private image only)
First you need to start VM without /rw mounted. One possibility is to interrupt its normal startup by adding the rd.break kernel option:
qvm-prefs -s <vm-name> kernelopts rd.break
qvm-start --no-guid <vm-name>
And wait for qrexec connect timeout (or simply press Ctrl-C). Then you can connect to VM console and shrink the filesystem:
sudo xl console <vm-name>
# you should get dracut emergency shell here
mount --bind /dev /sysroot/dev
chroot /sysroot
mount /proc
e2fsck -f /dev/xvdb
resize2fs /dev/xvdb <new-desired-size>
umount /proc
exit
umount /sysroot/dev
poweroff
Now you can resize the image:
truncate -s <new-desired-size> /var/lib/qubes/appvms/<vm-name>/private.img
It is critical to use the same (or bigger for some safety margin) size in truncate call compared to the resize2fs call. Otherwise you will lose your data!.
Then reset kernel options back to default:
qvm-prefs -s <vm-name> kernelopts default
Done.
In order to avoid errors, you might want to first reduce the filesystem to a smaller size than desired (say 3G), then truncate the image to the target size (for example 4G), and lastly grow the filesystem to the target size. In order to do this, after the truncate step, start the vm again in maintenance mode and use the following command to extend the filesystem to the correct size:
resize2fs /dev/xvdb
With no argument, resize2fs grows the filesystem to match the underlying block device (the .img file you just shrunk).
- Page archive
- First commit: 17 Jun 2018. Last commit: 17 Jun 2018.
- Applicable Qubes OS releases based on commit dates and supported releases: 3.2, 4.0
- Original author(s) (GitHub usernames): taradiddles
- Original author(s) (forum usernames): @taradiddles
- Document license: CC BY 4.0
