Should sys-whonix be disposible?
Should sys-whonix be disposable?
I use VPN before sys-whonix and worry too consistent guard lets correlation attack.
sys-whonix should not be disposable. See the Warnings section on
Specifically,
Ephemeral Whonix-Gateway ProxyVMs Using Disposables for both the Whonix Gateway and Workstation in Qubes does not increase security without any corresponding privacy downside, for the following reasons: [17] [18] [19]
  • Disposables are not amnesic. In practice this means traces of their activity can be left on storage or in memory, making them vulnerable to forensic operations. [20]
  • Using a Disposable for the Whonix-Gateway results in non-persistent entry guards to the Tor network; behavior unlike the default configurations for Whonix, Tor, and the Tor Browser Bundle. Mathematically speaking, end-to-end correlation attacks are more likely to succeed when a user chooses many random entry and exit points in the Tor network, rather than semi-permanent entry guards which are only rotated every few months. [21] [22]
  • See additional footnote. [23]
Actually, a quick question (or three) to @adrelanos . Would using custom-persist be a good approach to adding additional security granted by DispVMs and not reducing privacy? If so, which directories would need to be made persistent, just /var/lib/tor and /etc/tor? If so, do you think that would be a good idea to include as a default configuration for Whonix-Qubes?
