Should I autoremove whonix-gw-16?
what do you think should I autoremove whonix-gw-16?
user@host:~$ sudo apt autoremove
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following packages will be REMOVED:
  codecrypt cython3 debhelper dh-autoreconf dh-strip-nondeterminism diceware dwz equivs extrepo flatpak geoip-database intltool-debian kicksecure-recommended-cli libappstream-glib8
  libarchive-cpio-perl libarchive-zip-perl libavahi-glib1 libbytes-random-secure-perl libcrypt-passwdmd5-perl libcrypt-random-seed-perl libcrypto++8 libcryptx-perl libdebhelper-perl
  libexpat1-dev libfile-stripnondeterminism-perl libgeoip1 libmail-sendmail-perl libmalcontent-0-0 libmath-random-isaac-perl libmath-random-isaac-xs-perl libostree-1-1 libpython3-dev
  libpython3.9-dev libsnappy1v5 libstemmer0d libsub-override-perl libsys-hostname-long-perl libyaml-libyaml-perl magic-wormhole makepasswd po-debconf pwgen python3-attr python3-autobahn
  python3-automat python3-bcrypt python3-cbor python3-click python3-colorama python3-constantly python3-dev python3-geoip python3-hamcrest python3-hkdf python3-humanize python3-hyperlink
  python3-incremental python3-lz4 python3-nacl python3-png python3-pyasn1 python3-pyasn1-modules python3-pyqrcode python3-service-identity python3-snappy python3-spake2 python3-tqdm
  python3-trie python3-twisted python3-twisted-bin python3-txaio python3-txtorcon python3-u-msgpack python3-ubjson python3-wsaccel python3-zope.interface python3.9-dev zlib1g-dev
0 upgraded, 0 newly installed, 78 to remove and 0 not upgraded.
After this operation, 82.3 MB disk space will be freed.
Do you want to continue? [Y/n]
You can do these autoremove command(s). At least I’m doing that too. If somethings is missing I can install that package again.
But If you not sure in the end, you also can wait, if someone (with some more Qubes knowledge) comes up with better info.
Re-install Meta Packages and Safely Run Autoremove
