Setting up an audio VM
I am trying to create an audio VM for my bluetooth headphone. I know it should be possible in 4.1, but I can’t find any documentation on how to do it. Can anyone shed some light into it?
Many thanks :slight_smile:
No official documentation AFAIK, but advice here may be of help:
https://linuxadministration.us/bluetooth-headset-with-qubes/
There is indeed no documentation about that yet. But there is salt formula to set it up: qubes-mgmt-salt-dom0-virtual-machines/sys-audio.sls at master · QubesOS/qubes-mgmt-salt-dom0-virtual-machines · GitHub (not tested too much…)
@fepitre can you provide commands to set it up?
Thanks for the reply. I managed to set sys-audio up using the salt formula provided, however it just broke all audio and now I can’t hear anything :frowning: I will keep trying to fix it and will post any updates here.
Still no luck in setting it up, can you provide some instructions @fepitre? This is the only thing missing so I can make Qubes my main OS.
I would like to point out that there seems to be a bug with the default audio vm salt files. If I install it, it will not let me shutdown sys-audio if it is being used as an audio qube for other vms. While this is expected behavior, what is not expected is that it considers sys-audio to be the audio VM for itself, so sys-audio can not be shutdown unless sys-audio is already shutdown :smile:
But why is this expected? I expect that I can shut it down and have no sound.
It’s the same behavior that is implemented with network vms, that’s why I would expect this.
I can provide instructions later in the next week.
Any news on this topic?
Unfortunately no, I’m currently busy with prior tasks.
For those that might stumble upon this thread in search for a solution for using bluetooth headphones with Qubes, I solved this temporarily by purchasing a bluetooth adapter into 3.5mm audio jack. Just make sure to get one that supports TX mode, like this one
So I got myself an audio-vm using
qubesctl state.sls qvm.sys-audio
removed pci-devices, set it’s audiovm to None (because the system would freeze on starting sys-audio and I think that was because of circular audiovm definitions?)
I installed qubes-audio-daemon from qubes-vm-*-current-testing
When I start a Qube which has audiovm set to sys-audio and run
pactl-simple-vchan [xl-id] [name]
I get an audio-stream which is visible in pavucontrol and, as pci-devices where still connected, audible.
My main usecase is using usb-audio and bluetooth without any touching dom0. When I connect my usb-headset to sys-audio, it is correctly detected and shows up in pavucontrol. However, when I use pactl-simple-vchan, I hear nothing. pavucontrol shows audio playback via the headset (the sound-bar jumps back and forth).
Even weirder, starting playback inside sys-audio works perfectly fine and keeps on working if I start pavucontrol while playback is audible.
Am I missing some pulseaudio/alsa/modprobe setup?
Just got this working.
Roughly the steps that I can recall now were to download the template vm that the sys-audio salt state uses - the salt states can be found here btw:
and fedora-33-xfce is the template vm it uses.
Once the state is run and the sys-audio vm created the template vm needs to have the qubes-core-admin-client rpm installed - this provides the qvm-start-daemon python script that is used to start the pacat processes for each vm audio client.
Next, startup the sys-audio vm and create ~/.config/autostart entries for qvm-start-daemon and pulseaudio:
eg. ~user/.config/pulseaudio.desktop
[Desktop Entry]
Name=Pulseaudio
Comment=Starts Pulseaudio
Icon=qubes
Exec=pulseaudio
Terminal=False
Type=Application
NotShowIn=KDE;
eg. ~user/.config/qvm-start-daemon.desktop
[Desktop Entry]
Name=Qubes Guid/Pacat
Comment=Starts GUI/AUDIO daemon for Qubes VMs
Icon=qubes
Exec=qvm-start-daemon --all --watch
Terminal=False
Type=Application
NotShowIn=KDE;
Next there are some problems with the policy that the salt state creates. It’s a bit of a pain to work though but the popup notifications are helpful - the policy is defined in /etc/qubes/policy.d/50-sys-audio.policy on dom0
I’d paste it here but tbh I’m a bit lazy and it’s on dom0 :stuck_out_tongue:
Finally, each vm needs to have the audiovm adjusted w/
eg. qvm-prefs audiovm sys-audio
Oh yeah, and I went into services on sys-audio and added the audiovm services.
Oh, and those .desktop files are in ~user/.config/autostart
Thanks for the instructions, I will try and post my results here.
Edit: I got a working audioVM, after a lot of troubleshooting and banging my head against a wall.
I will try to optimize the process and will post clearer instructions here when I have the time.
I was able to run the salt formula and create sys-audio.
I successfully had sys-audio handling my soundcard, but I cannot create pulseaudio streams to it.
I used pacat-simple-vchan (dom-id of sys-audio) sys-audio in appvms, and most of them said command not found.
So I installed qubes-audio-daemon in my templates of my appvms. Now the command could be run, but nothing happened. No new “Application” stream in sys-audio. After I set qubes-prefs default_audiovm sys-audio, newly created qubes didn’t created streams in dom0, but not in sys-audio either, even after I had rerun pacat-simple-vchan.
So could anyone help me please? Thanks in advance.
Update:Now I’m able to see virtual streams in sys-audio pulseaudio control panel.
However, playing songs is impossible because the pulseaudio doesn’t automatically update the sound buffer. I made this guess because everytime I click at any botton of the pavucontrol window, the sound will update a bit and replay that bit again and again(making a lot of noise). As long as I click quick enough, I can tell from the rather scratchy and intermittent sound that the song is being played.
So how can I fix that? Thanks.
