using a Fedora-based sys-usb VM and a Whonix WS-based application VM:
navigate to the Trezor instructions page and read them. They are more frequently updated than this document.
in dom0:
sudo vim /etc/qubes-rpc/policy/trezord-serviceadd this line:$anyvm $anyvm allow,user=trezord,target=sys-usbreplacesys-usbwithdisp-sys-usbif you are using a disposable sys-usb -
in the sys-usb VM, or for disp-sys-usb, the VM on which it is based (in both cases, assumed to use a fedora-3x template):
sudo mkdir /usr/local/etc/qubes-rpcsudo vim /usr/local/etc/qubes-rpc/trezord-serviceand add this line to trezord-service:socat - TCP:localhost:21325 -
in the whonix-based application VM:
pip3 install --user trezorsudo vim /rw/config/rc.localadd this line (note the “&” at the end):socat TCP-LISTEN:21325,fork EXEC:"qrexec-client-vm sys-usb trezord-service" & -
in the fedora-3x template:
sudo dnf install trezor-common -
download the bridge RPM from https://wallet.trezor.io/#/bridge and remember to verify it!
copy to fedora-3x
in fedora-3x
sudo rpm -i /path/to/trezor.rpm
- Page archive
- First commit: 27 Aug 2021. Last commit: 27 Aug 2021.
- Applicable Qubes OS releases based on commit dates and supported releases: 4.0
- Original author(s) (GitHub usernames): null
- Original author(s) (forum usernames): N/A
- Document license: GPLv2
