Hello, if possible, unless there is a "community guide" I need step by step how to use my 2nd HD/M.2-Nvme for storage. Preferably encrypted.
I used a web search and got part of the way , however, I need clear step by step, all the way to mounting and actually using the block devices.
I’m not finding I can understand the terminology of
I realize some of it will not be “qubes-specific” if anyone is willing,
best regards
If you have both HDD and NVMe, you should make two storage pools, one for each storage type.
https://www.qubes-os.org/doc/secondary-storage/
