Setting "maxmem" from SaltStack
I’m working on encoding some of my setup in SaltStack and I come across an issue. I can’t set maxmem from SaltStack. If I set it with qvm-prefs works fine, but then I apply the state, and the SaltStack clears the setting.
{%- from "qvm/template.jinja" import load -%}
include:
  - sys-usb.tpl.at-dom0.create-tpl-dvm
{%- set qube_name = pillar.sys_usb.qube_name %}
{%- set tpl_name = pillar.sys_usb.template %}
{% load_yaml as defaults -%}
force: True
require:
  - qvm: "sys-usb.tpl.at-dom0.create-tpl-dvm/{{ tpl_name }}-created"
name: {{ qube_name }}
present:
  - template: {{ tpl_name }}
  - class: DispVM
  - label: red
  - flags:
    - net
prefs:
  - netvm: ""
  - virt_mode: hvm
  - memory: 600
  - maxmem: 3000
  - provides-network: false
  - vcpus: 2
  - autostart: true
service:
  - enable:
      - qubes-usb-proxy
  - disable:
      - network-manager
      - meminfo-writer
{%- endload %}
{{ load(defaults) }}
I tried also bare qvm.vm but result is same.
[greg@dom0 ~]$ qvm-prefs  sys-usb
audiovm             -  None
auto_cleanup        D  False
autostart           -  True
backup_timestamp    U
debug               D  False
default_dispvm      D  tpl-sys-usb-fedora-41-dvm
default_user        D  user
dispid              -  8289
dns                 D
gateway             D
gateway6            D
guivm               D  dom0
icon                D  dispvm-red
include_in_backups  -  False
installed_by_rpm    D  False
ip                  D
ip6                 D
kernel              D  6.12.25-1.fc37
kernelopts          D
keyboard_layout     D  pl++
klass               D  DispVM
label               -  red
mac                 D  00:16:3e:5e:6c:00
management_dispvm   D  default-mgmt-dvm
maxmem              -  3000
memory              -  600
name                -  sys-usb
netvm               -  None
provides_network    -  False        qid                 -  63        qrexec_timeout      D  60
shutdown_timeout    D  60
start_time          D
stubdom_mem         U
stubdom_xid         D  -1
template            -  tpl-sys-usb-fedora-41-dvm
updateable          D  False
uuid                -  68de91b1-0e9b-4ef8-ba9a-8c727e32710f
vcpus               -  2
virt_mode           -  hvm
visible_gateway     D
visible_gateway6    D
visible_ip          D
visible_ip6         D
visible_netmask     D
xid                 D  -1
// then apply
    Function: qvm.vm
      Result: True
     Comment: ====== ['present'] ======
              [SKIP] A VM with the name 'sys-usb' already exists.
              ====== ['prefs'] ======
              [SKIP] autostart          : True
              [SKIP] virt_mode          : hvm
              [SKIP] maxmem             : 3000
              [SKIP] memory             : 600
              [SKIP] netvm              : None
              [SKIP] provides_network   : False
              [SKIP] vcpus              : 2
              ====== ['service'] ======
              [SKIP] Service already in desired state: ENABLE 'qubes-usb-proxy' = Enabled
              [SKIP] Service already in desired state: DISABLE 'network-manager' = Disabled
     Started: 12:56:54.371663
    Duration: 540.848 ms
     Changes:
              qvm.service:
                  qvm.service:
                      meminfo-writer:
                          new:
                              Disabled
                          old:
                              Missing
    Function: qvm.vm
      Result: True
              [SKIP] memory             : 600
              [SKIP] netvm              : None
              [SKIP] vcpus              : 2
     Changes:
              qvm.service:
                  qvm.service:
                      meminfo-writer:
                          new:
                              Disabled
                          old:
                              Missing
Thoughts?
Because the qube is already present and with the desired configuration?
This is because you are disabling meminfo-writer, which disables dynamic memory
management.
What do you think maxmem would represent in this case?
