I know it is possible to manipulate CPU share for a VM using
xl sched-credit2 -d <qube> -w <weight>
However, that needs the qube to be running.
What is the way (if any) to set priority/weight of a qube when it is not running or upon start?
I don’t know for sure, because I never tried, but I would explore a libxl hook, as the one described in a recent “mutually exclusive/anti-affinity” thread.
One could use GitHub - 3hhh/qubes-callbackd: Daemon to react to Qubes OS events. for that.
https://wiki.xenproject.org/wiki/Tuning_Xen_for_Performance
Maybe that page can help you?
Well, if it comes to scripting it, I can do it like:
However, I was hoping for a more elegant solution, like e.g. having a preference (qvm-prefs) for that. IIUC, there is no such thing though.
You can just add more VCPUs in the qube settings.
How does that work in regards to prioritization?
What if qube A and qube B both run only one single-threaded app (as the main CPU load). How would adding/removing VCPUs change priority of A and B?
