Might be missing something obvious here: Is there a straightforward way to select and unselect applications shown in app menu with the terminal similar to the gui utility. I’m aware of the qvm-appmenus utility and read this. However I have not found a way to make it work yet.
You can use qvm-features to change the menu-items and menu-favorites
This works perfectly well. Thank you very much.
